cant plug my car in @ laptop what kind of adapter?
cord
33
Nov 2, 2011
anchorage, Alaska
got tunerstien today with oem fit plug at the data link. problem is the the end you would plug into the laptop is a 9 pin sierial port. my lap top has a 15 pin port.
should i adapt 9 pin to 15 pin? the guy at best buy says i need an adapter 9 pin to usb. what do i do?
The 15 pin connector is a VGA video output not a serial port.
You want a keyspan USA-19HS usb to serial adapter or some other brand that also uses the FTDI chipset which supports the non-standard bit rate of a 1G ECU.
