4gfun
Supporting VIP
- 2,012
- 56
- Dec 10, 2007
Ask Me,
Virginia
I have been using the How To from this URL:
http://www.dsmtuners.com/threads/1g-clutch-pedal-removal-install.389980/
I have done everything that the How To mentions. I just have one problem. There is a piece of metal getting in the way that the assembly is getting hung up on.
The how-to cites being able to rotate the assembly. My Speedo cable is completely out of the car along with the steering column and I can't rotate the assembly much less get it past the below notch no matter what I do. I don't really feel like using an angle grinder down there and it seems strange that I'd need a hammer.
Here is a pic of the hangup circled in red.
Any ideas?
P.S. The how to misses the fact that you must not only remove the cotter pin to the brake pedal, but you must also remove the elements that it holds, e.g. the white washer behind it and the pin to release it from the master. I also noted a spring that goes to the clutch pedal that wasn't noted. The longer part of the spring faces the driver's seat. Finally, I had to carefully wack the studs for the slave cylinder towards the firewall to help free the pedal assembly.
Any ideas?
