ECUflash Cant log load
What version of Evoscan are you trying to use?
Evoscan likes to install a secondary directory where it keeps it's config files. It's in Documents. To fix mine, I not only had to insert the 2.7+ .xml file ceddy made into the correct location but I also had to remove all other .xml's to avoid conflicts.
C:\Users\_yourname_\Documents\EvoScan 2.9\DataSettings
If you have 2.9 then the 1byte load for ceddy mods should already be setup. Just select ceddy mods in the ecu dropdown in evoscan.
But you need to make sure it is referencing the correct address in your MUT table. If you rightclick edit in evoscan you'll see what the reference ID is (probably 41). That value under 4,1 in your MUT table needs to match the one in your rom xml.
I'm using a tephra mod rom with 2byte to 1byte load factor (evo8 ECU). This lets values exceed 255 :thumb:
I thought ceddy had released a mod for big maps for your ecu? I could be wrong but I thought I read that somewhere.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
