Can't find correct fitting
eDeclpse92
351
4
Sep 6, 2008
Belleville, Illinois
Hi, I am installing a fuel pressure gauge using an Autometer Isolater so fuel does not actually enter the cabin of the vehicle. I have a Fuel lab AFPR (not mini version) and so far I went to Lowes to find the fittings for the installation of this gauge and came up short. What I have so far is 1/8" MIPxClose coming out of the AFPR and a 1/8" in FIP T-connector connecting to that so one side will be connected to my Fuel lab stock gauge and the other side will connect to the gauage inside the cabin using the Autometer 5282 Isolator. Auto Meter High Pressure Gauge Isolators 5282 - SummitRacing.com
The only thing the isolator would thread into at lowes was a 1/4" in FL (part number P124678) What connector do I need to connect the isolator to the T-fitting?
The photo shows my set-up if there is any confusion. The blue case thread tape is where the afpr would be. If you have any insight in to this, it would be much appreciated. Thank you.
