Cant find coolant leak!!
96dsmftw
Supporting Member
293
248
Jun 23, 2011
Richmond, Kentucky
I have a leak of coolant that is not terrible but still enough to get me on here. For the past few weeks there has been a trail of coolant from under my car in the morning, and the weird part it only happens on Sunday mornings, after sitting overnight. Anyways, the firewall inside of the engine bay is dry and I have looked all over and cannot find it. It is on the drivers side, almost looks like under where the steering column goes through the bottom of the car. Below is a video.
It is dripping through that seam in the metal. I don't know where it is coming from. Is there coolant going to the power steering?? Looked through the haynes manual and didnt see anything. THanks
Get a coolant pressure tester. It is a pump that goes on your coolant pressure cap. Apply pressure and search leaks. They are kinda pricey, but if you can rent one or get one from a friend....it is your best bet at finding the leak easily.
You can rent one from any auto zone with just a deposit. Also use uv dye that's made to go in coolant and the uv light (they sell kits) and either run the car or use the pressure tester. You'll see the dye glowing under the uv light.
Again agreed you need a pressure tester to locate the leak. Could be coming from your water pump possibly if it comes from the drivers side area like you said.
