Cant find axles Swapping transmission help!!!
coryf1233
246
Nov 6, 2007
hanover, Pennsylvania
I cannot find axles for my 1994 fwd tsi, no one can for that matter, slowboyracing included. this is my daily driver, I know 93 and 94 have 23 spline count, but if i use a 91-92 trans i will be able to find axles for those years. so is it possible to use the 91-92 trans and axles.
Desperate for help
you should be able to find the axles at a local auto parts store I think there like $180 new but I have the same kind of problem Ive got the same car my tranny broke and I dont have the money to spend on buying a new one or getting it rebuilt ive been trying to find one used but all I can find are 90 91 trannys if you figure out how to set one in your car let me know.:pray:
I am not sure that all 93-94 tsi fwd have the 27 splines opposed to the 25, did you check yours to be sure?
You can switch for a 91-92 trans(do not put a 90, it will not fit with your câble...).
You can also switch your front differential for a early 1g tsi fwd and changed your axle or you could also buy some 2g tsi fwd axles(27 splines) and only used the end cups if they are to long.
I know that the 2g driver axle fit on my 1g but im not sure if the smaller one is to long for 1g.
I know that here it is liked impossible to find these, every auto parts only have the 25 splines, I have 2 sets here but your a bit to far from me...
Steve
