2G Cannot remove output shaft seal
gsxlol
Jul 29, 2012
Gonzales, Louisiana
I am trying to replace the output shaft seal. I bought a seal puller which just wont fit in there to reach the seal. I tried using a bent screwdriver. i tried biting onto an allen wrench with some vice grips. everything i have tried has failed thus far. I'm sure several of you have been through this and have created your own "simple tricks" to getting it out.
this is a 2g eclipse gsx fyi
ill go try this right now.
that hasnt worked at all. ive been trying every little thing i could think of.
any other ideas?
You obviously aren't trying hard enough. If you hammer a flat head screw driver thru the metal part of the seal, it sill deform the seal and it will be real easy to get out. Use more force.
Although I've never removed an output seal specifically, I have found that ^^^^^^ particularly true. Also, needle nose vice-grips will do some great work when it comes to seals.
Screwdriver through the outer metal part of seal and pry it out. Works every time. Do not put the screwdriver between the seal and casing. Only the seal itself.
