can your dsm have bent valves and not show it
miller97tsi
221
Jan 5, 2008
jacksonville, Florida
i took my head off and did not see any bent valves. but when i look at the top of my pistons it had indications of the valves kissing the pistons on the exhaust side. is this possible also i had 60 psi on all for cylinders when i did a comp check. what can be going on
I would bet the timing messed up before, bent the valves, and they just installed other used valves without even lapping them in. Usually bent valves give close to 0 compression numbers. Either way you probably need a valve job.
see here is what i found. when i took the exhaust mani off and looked into the valve chamber there was oil residue on the valve itself is that normal? i am not sure and if that were the case would i be leaking air from a comnp test?
Pour some water into the intake/exhaust ports on the head. If it leaks, your valves are more than likely bent or not sealing properly.
Even just a tiny tiny tiny bend will cause compression problems.
+1
turn the head to each side (intake/exhaust) so that if your looking down at it you can see in the ports, pour water in there doesn't matter how much even the littlest amount will work. if your valves are bent at all even the tiniest bends will show, water will leak past the valves, if no water leaks past and the ports hold all the water, that valve(s) is good. :thumb:
ok one last question, if my exhaust valves put small indentations in the top of the pistons will that hurt anything? they are not real big but i have never seend this before, any suggestions?
Are you sure you aren't talking about the valve relief that is cut into the piston? :)
And...if you have bent valves, you'll most likely know it.
depends on how hard the valves met pistons.... you can pinch ring lands when valves bend, and the rings get pincehd and not move like they should.
