Can this ecu be fixed??? Can someone here fix it???
well i got the injectors and eprom from my buddy and its been rebuilt with new caps already. i just need that little burnt part repaired.
thanks
david
I'd guess the same ballpark. Depends on how bad the board is burned and what else shows up. Is that
Have you figured out which of the BCS or FPS shorted to 12v and caused the driver to burn up? You don't want it to do it again.
Since it's common to replace the BCS and leave the BCS connector flopping around loose where it can get wet and short out is a good possibility. Did you try running the fans off the BCS harness?
Steve
Steve
so do i just mail the ecu to you then you give me a quote on what its going to cost to repair it? i had it connected to the BCS and have since cut the ends of the wires clean.
That's how it works. Once I see it I can tell you what shape it's in and what should be done to it.
Remember to put all your contact information and instructions in with the ECU. I have a couple sittling here with nothing but a return address on the box that I have no idea what to do with.
Email or call me if you have any other questions, we crossed over to customer support and that's against the rules here.
Steve
