Can the mafs cause stalling?
BudmannG
129
Aug 7, 2004
Waverly, Illinois
I was wondering if the air flow sensor would cause the car to stall? I have a HKS on my car now, but the filter part is gone. And that leaves the sensor to all the elements. Could this be the problem for engine stall? :talon:
so you dont have an air filter on the car?if so,yea that will stall it because the mas gets a bunch of crud in it and can meter air like it should.plus all that crap goes throughout the engine.
So is there a way to clean the air flow sensor? I mean is there a special cleaner or solvent I should use? :talon:
you could probably use that electronics cleaner spray they make for computers and such.i think they sell it at walmart.
OK, This is what I did. I went and got some sea foam and cleaned the mafs. The masf almost looks new now after I did that. Put it back on and it still stalled. So I took my aftermarket intake tube off and put the stock tube back on. Now there is no stalling at all and I get more boost. I was running only 9 psi with the after market intake tube. Now with the stock intake tube I am running 12-13 psi. I for one don't understand this at all but I took pictures of the aftermarket tube so you could all see. Just click on the pic and it should maximize. And I highlighted concerns of my own on the welding of this tube. If anyone has any idea why this tube made my car stall. Please let me know. I also inspected the outside of this tube and I can't see any holes by the naked eye. :talon:
I found my stall, But it still does an idle surge on cold starts. If the car is moving around 5-10 mph and come to a stop sign it runs up to 2500 and cuts back to 1500-2000. It does this for about a minute and then settles at regular idle. That is annoying!!!!!! WTF :talon:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
