Can someone Identify this connection?
marineeagle28
94
Aug 30, 2009
Jacksonville, Florida
I am including a pic.. This connection appears to be factory wiring. I found it behind my rear seats/ trim underneath the carpet. The wires coming out of the pigtail are solid red, solid black. It is located behind the rear seat, drivers side. I found it with the wires cut, but i can not locate where from. Help please?
By tyberius1895 at 2011-10-21
thanks for the suggestion, but mine still turns on, so it doesn't belong to that.. i know of 2 problems with the car/ electrical toys, power mirrors, and windshield sprayers don't work.. I am currently in the process of checking the sprayer motors for function... the switches work.. Pulling the resevoir to check the electrical connections/ ground and backtrace the wires looking for shorts
Thanks though KTGurl
Edit: FYI the wires for the hatch light are red with black stripe and silver dashes, and red with green stripe and silver dashes (at the connection anyway) I can see them easily as I have disassembled all interior trim pieces from doors back!
Pulled the reservoir already... all electrical connections connected to the reservoir it self check out for continuity.. time to keep going...
EDIT: Okay, I have concluded that the problem with the squirters is not with the wiring, all check out for continuity, checked with multimeter on every AFT connection point. The ones vehicle side only have continuity when switches are depressed, so that is good. So I tried to check the motors with wire leads connected directly to a 9v. Battery, nothing.. Tried with leads connected directly to a 12v battery, again, nothing.. I am thinking the motors/ pumps themselves are done.. Anyone have any different thoughts? If they are done, can anyone point me in the direction where I may find some new ones?
They wrong but thats for your speakers that are on the back seat.
not those either, Re-ran those wires, as mice had eaten through the factory ones at the speaker connections, and those wire colors are yellow/blue stripe/ silver hash marks: gray/blue stripe/ silver hash marks (driver side) and yellow/ red stripe/ silver hash marks: gray/ red stripe/ silver hash marks (passenger side).
ALL of my lights in the rear are fully operational (brake, tail, turn signals, and reverse lights. I have a non- powered radio antenna, and it is functional. Last I had the vehicle on the road ABS was also fully functional.
Thank you for the suggestions though, Please keep them coming before I start tearing my hair out!
Alex
On your washer motors mine were both bad.
Napa has them way cheaper than the dealer.
Can't remember, I think they had to match them up.
Are you sure thats a factory plug? May bee It was for an after market amp.
Good luck!
Post number 30 lets see what happens now. :)
