ECUflash Can read a rom with Ecuflash but it won't flash back
RedTsi_PR
227
Jun 19, 2011
San Lorenzo, Puerto Rico
Hey guys i'm new to this whole ecuflash thing and i have my 1G already setup for a blackbox ecu. i've been reading a lot and decide to give it a try. The thing is the first time i did a read and flash everything went perfectly but since that the Ecu won't let me Flash again only read the rom from the ecu. Here's the log file from Ecuflash :
[16:26:53.871] Logging to file C:/Users/Bernardo/AppData/Roaming/OpenECU/EcuFlash/logs/ecuflash_log_20161022t162653.txt
[16:26:53.871] EcuFlash Version 1.44.4799
[16:26:53.871] OS Version Windows 8.1
[16:26:53.871] Kernel Type winnt
[16:26:53.871] Kernel Version 6.3.9600
[16:26:53.871] CPU x86_64
[16:26:53.871] Product Name Windows 8.1
[16:26:53.871] Product Type windows
[16:26:53.871] Product Version 8.1
[16:26:53.871] Qt Version 5.6.0
[16:26:53.871] Qwt Version 6.1.2
[16:26:53.871] QwtPlot3D Version 0.2.6
[16:26:53.871] Boost Version 1.60
[16:26:53.871] FTDI Library Version 3.02.11
[16:26:53.871] Openport J2534 Library Version 1.02.4798
[16:26:53.918] 67 memory models read.
[16:26:53.934] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[16:26:54.559] 759 ROM metadata models scanned.
[16:26:54.559] checksum module "subarudbw" loaded.
[16:26:54.559] checksum module "subarudiesel" loaded.
[16:26:54.559] checksum module "subaruhitachi" loaded.
[16:26:54.559] checksum module "mitsucan" loaded.
[16:26:54.559] checksum module "mitsuh8" loaded.
[16:26:54.559] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[16:26:54.559] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[16:26:54.590] using metadata XML ID read_evo65 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_evo65.xml
[16:26:54.606] flashing tool "wrx02" loaded.
[16:26:54.621] flashing tool "wrx04" loaded.
[16:26:54.637] flashing tool "sti04" loaded.
[16:26:54.637] flashing tool "sti05" loaded.
[16:26:54.653] flashing tool "mitsucan" loaded.
[16:26:54.653] flashing tool "mitsukernel" loaded.
[16:26:54.653] flashing tool "mitsukernelocp" loaded.
[16:26:54.653] flashing tool "mitsubootloader" loaded.
[16:26:54.653] flashing tool "shbootmode" loaded.
[16:26:54.653] flashing tool "shaudmode" loaded.
[16:26:54.668] flashing tool "subarucan" loaded.
[16:26:54.684] flashing tool "subarucand" loaded.
[16:26:54.699] flashing tool "subarubrz" loaded.
[16:26:54.699] flashing tool "subaruhitachi" loaded.
[16:26:54.778] J2534 API Version: 04.04
[16:26:54.778] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[16:26:54.778] Device Firmware Version: 1.16.4769
[16:26:54.778] Device Serial Number: TAJf7E2y
[16:26:54.778] interface close
[16:26:54.793] J2534 API Version: 04.04
[16:26:54.793] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[16:26:54.793] Device Firmware Version: 1.16.4769
[16:26:54.793] Device Serial Number: TAJf7E2y
[16:26:54.793] interface close
[16:26:54.809] J2534 API Version: 04.04
[16:26:54.809] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[16:26:54.809] Device Firmware Version: 1.16.4769
[16:26:54.809] Device Serial Number: TAJf7E2y
[16:26:54.809] interface close
[16:26:54.825] J2534 API Version: 04.04
[16:26:54.825] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[16:26:54.825] Device Firmware Version: 1.16.4769
[16:26:54.825] Device Serial Number: TAJf7E2y
[16:26:54.825] interface close
[16:26:54.840] J2534 API Version: 04.04
[16:26:54.840] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[16:26:54.840] Device Firmware Version: 1.16.4769
[16:26:54.840] Device Serial Number: TAJf7E2y
[16:26:54.840] interface close
[16:26:54.856] J2534 API Version: 04.04
[16:26:54.856] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[16:26:54.856] Device Firmware Version: 1.16.4769
[16:26:54.856] Device Serial Number: TAJf7E2y
[16:26:54.856] interface close
[16:27:06.262] using metadata XML ID read_evo5 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_evo5.xml
[16:27:06.293] using metadata XML ID read_evo5 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_evo5.xml
[16:27:16.703] opening rom file C:/Users/Bernardo/Desktop/STOCKread_image.srf
[16:27:16.750] using metadata XML ID 20780008 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/mirage/20780008.xml
[16:27:16.781] using metadata XML ID 20780008 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/mirage/20780008.xml
[16:27:21.265] J2534 API Version: 04.04
[16:27:21.265] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[16:27:21.265] Device Firmware Version: 1.16.4769
[16:27:21.265] Device Serial Number: TAJf7E2y
[16:27:24.469] sending init sequence 2
[16:27:24.469] got 0x11 response
[16:27:24.469] sending init sequence 3
[16:27:24.828] entering bootloader
[16:27:24.828] sending kernel size (2029)
[16:27:24.828] sending kernel load address (0x0000F000)
[16:27:24.844] uploading kernel
[16:27:25.187] verifying kernel checksum response
[16:27:25.203] kernel valid
[16:27:25.422] kernel get version
[16:27:25.422] kernel version is : OpenEcu Mitsubishi H8/539F Kernel V1.07
[16:27:25.422] reading kernel comm buffer size
[16:27:25.437] comm buffer size set to 256
[16:27:25.437] reading kernel flash buffer size
[16:27:25.437] flash buffer size set to 1024
[16:27:25.453] -- flashing image to ECU memory --
[16:27:25.875] -- comparing ECU flash memory pages to image file --
[16:27:25.890] seg start len ecu CRC32 img CRC32 same?
[16:27:26.031] LB7 00010000 00003000 54967767 DE3B6FA5 NO
[16:27:26.047] SB0 00013000 00000200 EAB4D18E 76338958 NO
[16:27:26.062] SB1 00013200 00000200 C5AC1954 5E037E97 NO
[16:27:26.078] SB2 00013400 00000200 3ADD03D2 57A01066 NO
[16:27:26.094] SB3 00013600 00000200 CDBE9460 EEEB9C6A NO
[16:27:26.109] SB4 00013800 00000200 74A85A31 BAF44EAE NO
[16:27:26.125] SB5 00013A00 00000200 9F6F7C4E BD7BC39F NO
[16:27:26.140] SB6 00013C00 00000200 ECC27417 BD7BC39F NO
[16:27:26.140] SB7 00013E00 00000200 BD7BC39F BD7BC39F YES
[16:27:26.344] LB6 00014000 00004000 0FBFDDA3 F1987EF8 NO
[16:27:26.547] LB5 00018000 00004000 954A35BC 32C77EDC NO
[16:27:26.750] LB4 0001C000 00004000 F899C587 002A1FDC NO
[16:27:26.953] LB3 00020000 00004000 341F4448 08AC465A NO
[16:27:27.156] LB2 00024000 00004000 1FED30F4 F813DC82 NO
[16:27:27.359] LB1 00028000 00004000 5BCEBA87 4C0506CE NO
[16:27:27.562] LB0 0002C000 00004000 ABCB1A08 2D8D9F88 NO
[16:27:27.578] kernel flash enable
[16:27:27.594] kernel blank flash page: addr: 0002C000
[16:27:42.703] WARNING: failed to erase page at 0002C000!
[16:27:42.703] kernel flash disable
[16:27:44.734] interface close
If you click the little car icon at the top of Ecuflash, which one is selected? I usually have to change it every time I start EcuFlash.
Maybe try the second option on that car lost. On my ecuflash, I think I have 3 options and I sometimes have to figure out which one is the right one.
I assume your flash connector is plugged in, right?
