Malenko
- 474
- 1
- Jul 29, 2002
Newark,
Delaware
basically I had a leak in my water pump/cooling system. Replaced the water pump and that just made it worse, so I took my car to RnK in Newark,Delaware. At the time, they were the only place that would touch my car. They said the head needed shaved.
2 months later they finally decide to finish my car, I re-flashed my ECU with the last good settings in my DSMLink saved folder. Now anytime I get on the gas and the turbo starts to spool up the car just stops wanting to accelerate and just sputters until I let off the gas. I checked for vacuum leaks and boost leaks and even replaced the plugs. Everything APPEARS to be normal but repeated calls to RnK have yielded no results, they want a couple of hundred just to look at it , and quite frankly they already raped me the first time and theres no way they are touching my car again.
I can post up a run from my DSM if it'd help at all, mod list in my profile. If I baby the car and keep the RPMs below 4K I drive, even getting the car up to 80mph with no issues, but as soon as I throttle it enough for the boost to build the sputtering happens.
I miss having AWD turbo
*FIXED* there was a boost leak somewhere, undoing and redoing all the intercooler piping and vac lines resolved the issue
