can i use a n/t trhottle body on a turbo 4g63?
Yup its possible. Best part is that you don't break the seal on the tb everytime you want to take off the upper ic pipe.
You guys all forgot that the shaft seals are not the same. You could take the stock seals and flip them over (works for some) or slightly drill out the TB to accept the turbo seals. Hooking it up as is would work, but more then likely you would get boost leaks. I ran one of these a while back until I found a turbo TB..:thumb:
so what you guys are saying is i could use n/t TB but need to replace the shaft seals from n/t to turbo seals? to be safe? im just trying to eliminate stuff out because my car drops idle when in gear its a/t so im trying to seal the FIAV with a plate and EGR to get rid of that.i don't want to buy the plates if i cant use the TB. ha-ha but thanks guys :D
ok will do. thanks one more question is off topic but if the egr is not in use i have it on i put hoses from one input to the other would that cause problems? im just trying to see if i should just remove it and block it off.
