Trhottle body question
agarcia892003
186
Feb 21, 2005
Green Bay, Wisconsin
k guys i did a boost leak test on my car today and i found out that my throttle body is leaking..should i just change both of my throttle body gaskets? are both of the gaskets the same? or are they different sizes...thanks in advanced..:thumb:
I just ordered both gaskets for $10 at SBR. Might as well change them both, in case one gets damaged when you take the TB off. Also, are you sure your throttle body shaft seals aren't leaking also?
You might as well since you will be taking it off. Its not a hard job at all either just follow the vfaq instructions on changing them:thumb:
agarcia892003 said:
k guys i changed my gaskets and my shaft seals..i still have a small leak by the idle speed set screw on the throttle body..is this normal? or did i do something wrong?
That's also a very common place for a leak - there's a little o-ring on the screw that gets hard with age. Easy to replace. Pick-up a #5 o-ring at the hardware store - size is 3/8 x 1/4 x 1/16. Here's a site with info on how to replace:
http://www.plymouthlaser.com/biss.htm
:talon:
I also bought a new BISS, o-ring, and cap for my car with my gaskets. I haven't even done a boost leak test, but I'm covering all my bases and doing some general maintenance. :)
