Can I use an N/A 4g63 block?
twinkiemobile
107
Jul 21, 2004
Tolleson, Arizona
Sorry guys, tried to search but i kept getting building up N/A blocks.
My question is can i use an N/A 6bolt block and build it up as a stroker for my DSM. i've read somewhere that you can use the 6bolt n/a crank with your bolt turbo block no problems but can you you a whole N/A 4g63 block and build it like it's a turbo block? if i remember correctly the only difference are the oil squirtirs correct? which many people cap off for forged internals anywayz.
thanks
- Jose
Yes you can. There are posts everywhere on here about the conversion. Just go to the NA forum or search turbo conversion (it tells what internals are dif). 6 bolt blocks swap with 6 blot blocks and 7 with 7. Difference with turbo motors are only minor. DO THE SEARC AGAIN
