420A Can I put the Dodge Neon 2.0 in my Eclipse?
Status
Not open for further replies.
lostindsmworld
Feb 19, 2011
rogersville, Missouri
Ok I am not here to be judged. Ii am here to ask a question so if you could just give me a stright answer that would be great. I can't find the motor for my car it is a 2.0 the 420a . I found the 2.0 that goes in the dodge neon. I know that the intake and the exsaute(dont know how to spell it) are backwards from the 420a but if I put my head on the 2.0 neon block would it work. I have found people online who have done it but I tought I meant ask u guys bc u guys really helped me out last time. Thanks for helping
thanks do you know if my tranny will bolt up to te neon block!!!! And do any of you know if the motor mounts are te same
All neon dohc and sohc 420a blocks are the same as the eclipse, talon, avenger, and sebring 420a except the sohc neon use different pistons. So yes the transmission will bolt up to the neon block but you will have to use your drivers side motor mount off your eclipse with the neon block and your other three mounts are on your transmission.
Please don't cross-post. If you're trying to decide whether to start a new thread or post in an existing one, we prefer you post in an existing one.
Status
