Can i put a 93 awd trans in my 92(6bolt)?
TsiBoosted4g63
93
Aug 16, 2009
Cherry Hill, New Jersey
Juts wondering if i can just swap a 93 trans into my 92 without changing anything? And do i need to change the transfer case?
A little more info needed. Is the 92 AWD? If the answer with that is yes then I dont see what the issue would be with the swap. Also there is a lot of info on this sight an you could of easily found your answer using the search feature.
yes it is all wheel drive, and im new to the site and i didnt know, but thanks for the help
