Can I get a 2g install kit for a 16g for my 1g auto???
91tizzy
459
Jan 19, 2008
Cincinnati, Ohio
Ok iv'e searched but can not find the answers i need....I have a 91 auto with a 13g....I have a 14b manifold...I know the water and oil lines wont fit so If I could get a complete list from a wiseman or just someone who knows every little nut and bolt I need to order in order to bolt it on, Im talkin what lines,gaskets, crush washers, evo III o2 hoousing or can I use what I have?? Im thinkin Im gonna get the turbo from punishment and get all the little nic-nacs from STM....If someone could go on there and see if they have what all I would need....the have new studs and gaskets sold individually so that is why I would need a list OR would a 2g install kit solve what I need.......PLEASE help im a little confrassled:confused:
i wouldnt be having problems if the dam thing was a five-speed....and yes it already has 450cc injectors.....any help would be so much appreciated I have complete and total faith in ya'll:thumb:
If i read you right, you have 13b, and want to go to a 16g? and you have a 1g m/t exhaust manifold? if so, you will need
Oil return line,
Oil feed line, 1g's are from the head if im correct (2gs from oil filter housing)
Gaskets, turbo, o2 housing, exhaust manifold, oil return
1g water line kit from SBR (inclused the bolts and washers and lines)
and the turbo
or if you got the cash
SBR 1g Auto Kit
someone will chime in, and probably tell me i'm missing something or I'm wrong :D
see, i told ya LOL, but could't even tell me i was close LOL
If I remeber correctly you will need the coolant line that goes under the center cartrige to the water pipe w/the correct banjo bolt. You could just hack the oil return line and replace with a rubber hose and clamps or just buy one for a 14b/16g. Also you will either need an safc or a 5 spd turbo ecu & 5 spd fpr so it does'nt run pig rich.
I would suggest checking the classified's for a 14b with all the lines usually around a $100 and quite the upgrade on it's own. then you'll have everything you need and a spare when you get the 16g.
Thank yall.....I originally bought a 14b setup from a five speed car(with lines and manifold for 125) without realizing the oil and water lines will not work:coy:....waiting to see what kind of prices joe comes up with for me:sneaky: but yeah I already have a five speed ecu installed with blue tops (previous owner did this) already runnin pig rich (stock fpr)...thanks again all:thumb: need to be rid of this 13g
    • george bromwell
    • pma1123
    • Sdcryan1
