Can Bad Coil Plug Wires Cause a Short?
1996Eclipse420a
162
Jan 12, 2012
Wilkesboro, North Carolina
Okay, so like I posted in the other thread.... Your coil has a plug on it of course, and then you have a plug that gives the coil voltage... well, those wires didn't have anything on them at all... they were just out in the open leaning on the valve cover. Can that cause those wires to burn and short out? I wrapped them up in electric tape, and haven't experienced the problem anymore.... lets hope it stays that way.
They can if they rub on the valve cover long enough. Are you talking about the spark plug wires or the electrial wires (the triangle connector at the coil) if they are secured good then they will not move and not get damaged. If your spark plug wires are damaged then voltage will short to the engine instead of going through the spark plug and cause a missfire, usually under load.
you just answered your own question :rolleyes:
From reading this i assume that there was no insulation on two spark plug wires?
...........yes...that will cause a short, because the spark is traveling through the wire and is going to come out the first chance it gets. in your case, the exposed part right near the valve cover.
Cayenne, I bought new wires about a month ago (spark plug wires) because my others were worn. It still didn't solve the short, and it wasn't throwing a CEL code. Talon... it's the wires that run into the rectangle connector... the piece that plugs into the coil to make it work... those wires were exposed and had hard crusty spots on them, so I taped them up and it hasn't had the problem since I left college yesterday.
so what I'm saying is the electrical wires on the connector.
That makes more sense. What I would do eliminate the plug by cutting it off along with the bad wire and connect the wires directly with each other. See if that works.
If that doesn't work, check the wires under the coil pack itself to see if there's any corrosion or something going on there.
If the coil pack checks out and your problem still isn't solved, you may have a bad power transitor
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
