Bad plug wires
sL98-Tsi
Aug 20, 2007
Warrenton, Missouri
Could bad plug wires be causing my car to have an idle surge/rough idle? I didn't really notice the idle sure until about a week ago. I just replaced the plugs, thinking it was that causing the problem. Under boost it seems to pull fine. Just curious if anyone has had this problem.
-Levi
It's not a big surge, maybe 200-400rpm. Could it be because of cams with a vacuum leak? My vacuum sits at about -12.
yes rough idle could be caused by it but the surge is most likely vacuum related! check your vacuum lines! vacuum problem could also cause the rough idle too!
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
