idt512
- 231
- 9
- May 4, 2003
Hemet,
California
Bought a 2g with a Walbro 255hp fuel pump without an AFPR, had a stock pump laying around so I put that in place temporarily until I get my 190lph pump. Anyway the problem Im having is the car runs lean at WOT (only .79-.85V on the logger), it runs perfect at part throttle and has no driveability issues, o2 sensor cycles properly. I add about 5% fuel on the SAFC and seems to have no change on the o2 voltage, Im wondering if its possible to have an o2 sensor that cycles properly but does not quite get up in voltage even thougth the AFR is correct, or do I have a faulty stock FPR?
Turbo is a T28 @ 7psi (until problem gets solved), injectors are Evo 560cc, my SAFC hi throttle setting is at -8%, I should have plenty of fuel with those settings
