Camber Alignment Question
aspekt9
344
4
Dec 25, 2005
Boston, Massachusetts
On my 92 GS I have stock suspension, is it possible to adjust the camber? If my rear left camber is at -1.2' and the the rest of the corners are between -0.1' and -0.7', will that -1.2' cause a pull or uneven wear on the tires? My toe is near 0' on every wheel. Thanks
i was told here you cant adjust camber on a stock suspension. you could buy a camber kit. then you could adjust 1 degree + and -. or there is probably a camber kit that allows you to adjust more. i think they are just for the front though. drive the car and then when you are up to speed, put it and nuetral and let go of the wheel. then see if it pulls.
