Alignment Question
neuralracing
770
Jul 16, 2003
San Juan, Puerto Rico, Central America
I'm getting an alignment tomorrow... my question is what are the factory settings (Toe/Camber) that the shop will recommend? What should I ask them to do so as to maximize handling but not eat up my tires in a couple thousand miles. My car is not a daily driver but it will be driven about 40 miles each way to the track (road coarse) once a month and 10 miles each way to the drag strip.
I have JIC's, ST Sway Bars, Energy Susp bushings and Megan Racing strut bars (front and rear)
I would highly recommend having them set the caster and toe at the stock levels. Camber can be adjusted a little bit on our cars but not too far. I would go with 1.6 in the rear and 1.2 in the front. Also if setting up for a road coarse it is best to be in the car when they align it because that will change the whole geometry of your car once you get in it.
Read the FAQ's and pick the toe range you want based on the driving you do. There are no adjustments for caster or camber on a stock DSM suspension.
Sorry I assumed when I saw your profile you had camber kit's on your car already. Depending on what series of JIC's you have they make plate's that you can adjust caster with but I would leave that alone. I have camber kits on my car from when it was lowered and those numbers I gave were the one's that I found make my car handle the best. Now that it is back to stock ride hieght it doesn't much matter but still... He is right though. On a STOCK dsm suspension you can't adjust caster and camber. Have to get kits to do this.
