cam upgrade or fail?.....
idomin8-420a
31
Mar 7, 2011
lithonia, Georgia
hello my fellow tuners had an idea but not sure of its compatibility but i need to know if the cams from the dohc 2.4l cirrus motor would fit the 2.0l dohc head from the 420a:hmm:
Never heard of anyone doing this so I'd say no, and even if they did I'm quite sure it wouldn't be an upgrade. Valvetrain parts (lifters, rockers) can be swapped though. Also you can swap the 2.4 Cirrus block to your 420A using the original 420A head.
You can't use the cams so don't try. For best results do what everyone else has done in the past. This is some interesting reading on camshafts and if you make it through it should give you a good idea on what path to take based off goals and current setup 2GNT.com Forums - Viewing topic #112272 - Camshaft discussion & comparison.
+1 :thumb:
