Cam Sensor location
grendels_arm
47
Apr 19, 2005
springfield, Virginia
1997 talon
OK I've ordered manuals so I'll know soon but is the cam sensor on the right side just below the top of the valve cover? And it has a 2 or 3 prong connector and 2 little bolts that hold it on. To replace the gasket (which my dealer told me is leaking but I don't really see much if any) is just a simple remove sensor, put on new gasket and put sensor back on job? Or is there aligning or timing or something to get worked out? :talon:
It's on the driverside, Pretty simple
Here is a pic.
The engine is GSGOINGFAST's
That's where I thought.
Would the dealer have to remove and replace this gasket anyway if they were going to get to the head gasket and therefore the valve cover gasker? I'm just wondering if there is any point in me replacing this gasket right now. Can I simply take out the 2 bolts, pop it back in after replacement?
