cam question
jldugger31
Mar 17, 2010
Athens, Alabama
just got the cam sensor in today was going to put it on but i cant get the cam to slip in...do i need to take the gear off and if i do will it make it hard for me to set the time later on?
You can usually clamp the t belt on the gear with a pair of vice grips. Use a rag between the vice grips and belt so you don't damage the belt. Then you can unbolt the gear and keep the belt/timing intact. It can be a little tricky, but you should be fine if you take your time.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
