CAM Gears? Good Idea or No?
n00btalon
197
Aug 13, 2005
lebanon, Pennsylvania
I think my stock ones are making a little noise... and i was thinking about picking some up, will new ones help me out? Or is it possible that it could just be the belt or no?
thanks
Your cam gears themselves shouldn't make any noise, they are directly bolted to the camshafts, so check if the are rubbing up against the cover or something like that. I'd look elsewhere before just changing the gears.
It is most likely just lifter tick. I would make sure you find out the actual problem before you just start throwing parts at it.
You could get revised lifters and that should fix it if it is lifters. If you decide to replace the timming belt then you NEED to replace the tensioner and the tensioner pullies as well.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
