kristoph
- 61
- 4
- Jul 20, 2015
mississauga,
ON, Canada
Good Evening Friends,
I just got my head cylinder back from the machine shop. I had them assemble my head with kiggly HP valve springs, kelford 272 cams and aem adjustable gears.
This is my very first engine build and I just want to be extra cautious. Does this look right to you. the gears clearly are not properly aligned, but being adjustable I guess the point is to set them once the timing is set?
I guess my question is, does the installation of the cams and gears appear to be correct ? two intake valves are open is this normal ?
I am assuming my next step is to install the test springs, and solid lifters, adjust for zero lash and set timing ? I had them assemble the head, despite the fact I would be taking it apart again to install the test springs because I wanted to look and learn how the cams are to be installed.
please advice.
Kris
please advice.
Kris
