cam bolt missing! /vent thread
check with your local tool store, they make a reverse direction drill bit, center punch the broken piece, once the bit grabs the bolt it should back right out. If you break off an easy out in that hole, you my friend have just f ed yourself.
Thats what I meant. I thought it was called an easy out.
an easy out is a reverse grabbing bit that is very thin, made out of VERY VERY VERY hard metal, that doesn't drill. You have to drill a hole first, then use the easy out.
Delta was recommending a reverse drill bit (just a regular drill bit that bites in reverse) to remove the broken bolt. If you are lucky this will work, but sometimes you just cant get around using an easy out. The benefit of the drill bit is that it is a bit more robust, and less prone to breaking because it isn't 'biting' the metal as hard as an easy-out.
Moral of the story: dont break an easy off in a bolt, because that metal is just too damn hard to drill into.
