CAI off turbo
shavers55
47
Feb 27, 2012
san diego, California
searched the thread could not find any answers to my question...so i've noticed that a lot of people run a short ram intake off their turbo. now my question is if i was to Fab a CAI would it be wise and or would i gain any performance from doing that?
I would think that a CAI would make a very small difference in comparison to the damage it could cause via a puddle etc. The air your turbo is sucking in is being compressed and heated anyways. After being compressed and heated its then routed threw your Inter cooler, my thoughts would be to had water sprayers to the inter cooler etc if your that worried about the temps.
probably should of just cleared this up in my OP (sorry). i just wanted to do it to say that ive done it..i threw a rod a couple weeks ago, before i get my engine put in im planning on running turbo on my 420A with stock internals. I just seen that alot of people run a short ram intake off their turbo. Just wanted to know if i "could" run a CAI off of it instead
Well, it would be easy with a 420a, theres no MAF, correct? It is just a matter of plumbing on the opposite side of the engine bay vs the gst.
correct no MAF, and yes just Fabbing from the opposite side. just want to know can i do it..( like if i do it will i hose something up)
You will have a significant drop in IATs. Its well worth it. Just, like others said, watch how low you put it and how deep the puddles are!
Even with the turbo heating the air, the actual IATs will be lower if your feeding the turbo colder air. I laugh at people with NA engines who tout their k&n "cold air intake" gaining "20 hp". BUT, with turbos, IATs mean the world performance wise. Drive a high HP setup on a 100 degree day, then on a 60 degree day. Massive difference in power.
Truth, temp makes all the difference in higher hp cars.
ok, question answered i will fab up a CAI when i drop my turbo..( or should i take baby steps and drop by engine) in my car...LOL..thanks guys
I wouldn't run a true cai personally. The extra length and extra bends will hurt performance more then the drop in iat's will help it. There is a thread somewhere on here showing the loss.
A better choice is a sealed air box, pressurized with outside air. Either from the grill, or from where the stock smic was.
The only thing with that link is, it need air from the outside. Thats more of a heat shield then an air box.
http://www.dsmtuners.com/forums/articles-intake-exhaust/194759-diy-cold-air-intake.html
You could also build something like this http://www.dsmtuners.com/forums/articles-intake-exhaust/194759-diy-cold-air-intake.html and make some ducting to feed more air through the hole for the stock SMIC UICP.
What he said^^
What he said^^
I'd have to disagree on that. What extra bends are you talking about?
