Buying a used Talon TSI...
SilverMPower
Nov 16, 2004
Milpitas, California
What should I look for when considering a used Talon TSI? I am looking at a 1991 with 151K.
Thanks.
do the normal, the 1991 have great motors in them, do a compression test.. Check transmission, brakes, hydraulic lines all the normal. Of course you should make sure the turbo is in good condition as well, if not it should be deducted from the pricing(if it has not already been taken into account). Also check all fluids and especially if the timing belt has been changed (should be changed every 60k) Also if it is manual, check the clutch. You can always tell a well maintained car if you look closely.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
