bushing on rear diff
travisgoldkuhl
66
Nov 11, 2012
tucson, Arizona
im having problems finding a bushing that is located on the front right side of my rear diff. none of the part stores iv called have it, is it a dealer item only? it keeps the front of the diff from rocking up and down while driving and mine is completely toast.
I hope this helps you out a bit. They aren't OEM bushings but they will help save your rear diff because they control it a whole lot better. Solid aluminum will give some vibrations while the poly filled will be very little if any! splitmotorsports.com/store/index.php?main_page=index&cPath=3_8
Thanks a lot, so it looks like the bushing on the front is the same as the ones that are on the top of the diff. Maybe that's why they couldn't find that front one because they are all the same.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
