Burning oil after boosting
Fayt
515
15
Mar 26, 2005
Cleveland, Ohio
I've searched and searched, but there are too many possibilities for what I could have. Here's the rundown.
Symptoms
After boosting, car puffs out blue-ish smoke. Oil.
No smoke on idle (except normal getting up to temp white smoke). But, once warm it doesn't smoke.
No smoke on normal acceleration/deceleration. If I go over 3psi in any gear, smoke will come out AFTER shifting, NEVER during boost.
My whole IC system, including my LICP, IC, UICP, BOV, TB elbow, TB, and IM are coated with oil.
Possible suspects
  • Oil return line was kinked on this turbo for about 100 miles. The kink has been fixed, but I fear my turbo's seals are shot. Turbo has no shaft play. My whole IC system (LICP, IC, UICP, TB elbow, TB, IM, etc.) has coatings of oil in it, along with the turbo inlet. I can clean the pipes then go driving around, 1/2 mile later, there is a small coating on the pipes. It never pools up though.
  • My valve cover was pushing a lot of oil out of it. Installed inline fuel filter, drove maybe 20 miles, and the thing is dirty as hell. Leads me to thinking I have excessive crankcase pressure. However, no dipstick popping out, yet.
  • My PCV valve is sticky. When I removed it, I blew in one end to make sure it worked fine, but I had to blow extremely hard to make it pop open. It seals fine from the other end. Probably coated with oil sludge. I'm going to clean it today, but what can I do to prevent it from building up?
  • Valve stem seals. I don't think it could be those because I don't smoke at idle at all. Nor is there wet oil in my exhaust runners.
Ways to fix the problem
  • I have a new Evo IIIg waiting to go in, but I am waiting until I know for sure what is causing this problem. If it is concluded that the turbo is the only problem, then it'll get installed ASAP.
  • I'm going to remove the PCV and clean it with degreaser, then test to see if it's sticking or not. Then, run an inline fuel filter between that and the IM to prevent future buildup.
  • My car will be compression tested later tonight, I'll post the numbers then.
I'm mostly looking for insight. Are these the correct methods to fixing this problem? Any other tests I can do to make sure, or things to look for?
i bet you have a combination of things. it sounds like the pcv is sticking and causing a buildup of pressure, which will blow oil into your i/c pipes and probably out the valve cover, because the pcv is designed to relieve the pressure and keep it pretty much neutral i believe. i know from experience that it will push oil through the turbo seals and will pretty much leak from then on.
i would guess that when you shift, that lets off the pressure off of the turbo, and the oil pressure is still high because the engine is still revving, even though the boost has dropped, i would guess that it is forcing its way past the seals.
You might consider installing a breather and catch can. i know RRE sells them.
http://www.roadraceengineering.com/eclengine.htm
scroll down and you'll see it.
as for the no dipstick pushing out, if it is blowing enough pressure by the turbo seals, or valve cover seal then there would really be no need for the dipstick to pop out. i never saw the dipstick pop out on my car when the pcv was clogged.
so my advice would be, change the valve cover gasket, i see your swapping the turbo, fix the pcv issue and install a crank case breather and oil catch can.
thanks
stay cool
Alright, cleaned the PCV, it doesn't stick anymore.
My valve cover is already hooked up to a catch can, I'll do the same for the PCV, run the car and see if the oil builds up again. If so, the turbo's getting done!
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
