Built motor, still problems....
Joshhasa99dsm
Mar 6, 2002
Texas
Kinda long synopsis, so here goes.....
99 GS, star II kit, eagle rods, je pistons, total seal rings, 1mm oversize valves, crane cams, crane springs, all clevite bearings, blah blah blah...the list goes on, so anyways.....
Took out the motor, sent it off to have shop assemble the motor. got it back put it in, didn't start. took the car to the shop and told them what happened and they said i had no oil pressure getting to the head and not working the lifters and they SAID they changed the oil filter and i got oil pressure up there.
Took car to get dyno tuned, blew something at 15psi. pretty sure it was head gasket. so took off head, got milled/decked/pressure tested (was warped) and put head back on with new HG and ARP head studs. after this i STILL have no compression, and now i have no oil pressure to my head AGAIN! Do i just have to crank on the engine all day long to get some pressure up there? Anybody got some suggestions? I wonder that if the starter doesn't crank it over fast enough, will it not turn the crank/oil pump pulley fast enough it won't pump fast enough to make decent pressure to the lifters, so could that be a problem also? it doesn't seem like it's turning over the engine too quickly either.....
Thanks,
Josh
did u break the motor in after the rebuild?did u check ur timming? or sensors?maybe crank sensor...just a thought..
yes, motor was broken in before dynoing. everything was completely fine until the dyno day. and i'm pretty sure it's not my sensors or anything like that. like i said in my first post, i don't have compression. something electrical would not cause me to have NO compression. timing is correct........
is the compression low on all cylinders? it can be a leak in the piston rings, or intake or exhuast valves. I doubt the cylinder head gasket could have broken so soon. do another pressure test and listen to where the air is escaping. If it leaks out of your intake filter than the problem is you intake valve. If it leaks out of your exhuast it's your exhuast valves.
how do i pressure up the cylinders without turning it over? if i turn over the motor to do a compression check, the motor is too loud and wouldn't be able to hear something like that...... btw, yes all cylinders have about 25-40 psi
