Car still smoking
black4banger
48
May 22, 2005
Pharr, Texas
Had a mechanic look at the turbo and oil lines since the car has been smoking alot! blue smoke....so i let him inspect it and he said the turbo was cracked. I had no time to do it myself so i gave him the money to buy another similar turbo. Started the car and its doing the same thing...........WTF!!!!!!! Head gasket? do i need a oil restrictor? but why would the turbo crack maybe not getting too much oil? dang it i dont know what to do .....help
try the manifold. But take it back to him and tell him to fix the problem. For all you know it wasn't even the original turbo in the first place.
My friend in his GSX, thought he blew his turbo when he started seeing blue smoke, (and yes that usually is the case), but after he bought a greddy 18g turbo kit and intercooler, he later found out it wasn't his turbo, it was just his manifold.
Its official god hates turbo neon motors this week OMG
Sorry to hear man.
Do a compression test. If that still doesent solve anything then I honestly don't know.
does the cars oil pressure change from when the car is cold to when its at normal temp.
Mechanic said that it smokes till it gets to normal temperature.
Maybe its at higher pressure at startup and then it lowers the pressure when the car is warm and maybe thats y it doesnt smoke at normal temp. maybe i need a lil restrictor in the oil feed line....................... :toobad:
i think maybe its just the oil thats left over in the exhaust pipes..........
u guys know anything about the fuel pump being reconnected after the battery dies or if u take the battery off u have to disconnect and connect the wires to the fuel pump...........
