buildup in exhaust side of turbo
1sloLASER
Feb 7, 2009
paso robles, California
ok so i picked up a 91 laser awd turbo.......its been sittin since 04 got it for a steal.:hellyeah: any way i pulled the turbo and there is a ton of what looks like carbon buildup in it but none on the manifold..head...or exhaust and its hard as a rock i tried chiselling it out only to do nothin any help??? new turbo??? grind it out??? what to do..id post pics cept i cant find my camera cord grrrr
Inside the turbine? Just leave it if the turbo doesn't smoke. Turbo probably came from someone who was venting their BOV.
well its on the inside of the housing it seems like its goin to restrict the flow of the exhaust and as far as i can tell nothin had been alterted from stock
Why did you have to pull the turbo?
If the shaft still spins freely it might be ok. Otherwise take some carb cleaner and a brush to it.
cracked manifold and it spins with no shaft play i just have to get it runnin now
Id clean the carbon out of it then reinstalled the turbo. Probly the car is running rich causing the amount of carbon build up. happened to me on my 94 tsi problem was the fuel system not being regulated properly.
Thats what I was thinking. My car was smoking really bad and when I pulled the turbo off there was a ton of burnt crap on the turbine heat shield. if its an ebay turbo they will leak oil into the exhaust even if there isnt any shaft play.
