Broken Bolts on exhaust side of turbo?
OverBoostinGST
273
May 15, 2005
Roselle, Illinois
I stripped two bolts off my 14b trying to take off the 1g o2 sensor housing, whats the best way to get them out? Anyone know what drill bit i would need because my craftsman drill bits arent working. Im thinking I should just take it to a shop, anyone know how much it would cost to just get two stripped bolts out?
i would take it to a shop...it shouldnt cost too much. I tried taking mine out and i ended up messing up the whole thing
Use a dremel with a cutoff wheel and cut the head off the bolt. The threads should now be sticking out with the o2 housing off. Spray some liquid wrench on the threads leading to the hole its in. Use a water pump plier(plumbers plier) to turn out the threaded bolt.
ya way too much. go to a local shop and ask theyll say something like 20 a bolt or something. Dont call a big place.
Sorry there not stripped yet there broken off into the exhaust side
ya if your worried about stripping it or messing it up let a local shop do it. If they mess it up they will usually re-tap it for you.
