nazthug
- 478
- 8
- Dec 24, 2003
livermore,
California
Ok, i have been reading many posts about engine building and i just get more confused, too many opinions, too many advices that are different, too many parts
I have a 99 gst, so i have the "newer" block with supposedly 2 piece bearing so it should have many problems with crank walking
It has 80000miles on it
I want to rebuild it soon to handle more power but mostly to be reliable and not worry about a blow up.
I am only aiming at about 350-400whp, i know some people say stock will handle it but thats not good enough for me, the engine has miles on it, it has been worked hard and i want to make sure nothing goes out.
I will keep it a 7bolt because i dont want the mess of a new block, and all that goes along with it.
I wil use my block and my crank to do the build
I am not super engine builder knowledged when it comes to the small details on machining, all the small parts required, rod bearings, main bearings, torque plate, hone, bore, seals, etc..
This is somewhat of a budget buildup so i dont want to spend too much.
I will be using Eagle rods and weisco pistons most likely
who does 7bolt builds?
Everywhere i look people either build or sell 6bolts
I want to stay with my 7 bolt, its the latest(99gst) and it supposedly has all the revisions so im not worried about crankwalk, plus its not as old so i dont have to worry about worn out blocks and cranks.
Let me have it guys
Should i send my block somewhere and have it all done? do it localy?
I can take it out and put it back in myself, but i dont know if i want to do the building myself, as i dont know which shop around here can do good machine work
Whats this torque plate stuff?
Anyways, i want a decent, strong and reliable engine to handle the power.
Some people say use the 1g rods, are they really that much beter? They are bigger, but still the same shity material as the 7bolt, them being bigger doesnt make them that much stronger, as far as material specs are concerned, if its only a size difference, it cant be more then 5-10% stronger, so i rather use eagle rods
Help me out guys
Let me have it guys
Help me out guys
... very helpful information.
