Build Parts List Feedback
needsy
94
Sep 21, 2008
NW, Iowa
While I have been a lurker for a few years now, I in no way consider myself an expert on DSMs. Therefore, I would like to solicit some feedback from those more knowledgable than I about the parts I have chosen. Let me know if you see a part that you think would be better than one of my choices and why you feel that way. Also, please chime in with any additional parts suggestions like, "while you have the transmission out you should also change/upgrade...".
My goal is to build a 2.3l stroker that will be a street/road coarse/autox machine. At this time I am using the T25 turbo until I can afford a proper upgrade. Right now I just want to get the bottom end built and replace/upgrade anything else that should be done while the engine and transmission are out. I plan on running e85 from the start.
Engine
Main Bearings -> ACL Tri-metal
Rod Bearings -> ACL Tri-metal
Crankshaft -> Topline 4G64
Pistons -> Mahle stroker
Rods -> Scat
Oil Pump -> Topline
Harmonic Damper -> Fluidampr
Gasket Kit -> Topline
Timing Belt Kit
Water Pump -> GMB - in timing belt kit
MBCAD
Balance Shaft Elimination -> OEM kit
Oil Squirters -> OEM
Engine Management -> ECULink
Hardware
Head Studs -> ARP
Main Studs -> ARP
Drivetrain
Flywheel -> Fidanza
Clutch -> Fidanza 3.2
Clutch Fulcrum Pivot Ball -> OEM
Clutch Fork -> OEM
Gauges
Boost -> Prosport
Oil Pressure -> Prosport
EGT -> Prosport
I would suggest a wideband more than an EGT gauge...just my 2 cents
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
