NA engine build parts list
slider85
469
May 21, 2004
Langley,
I want to, this summer, do an overhaul to my car. I want to rebuild the engine and tranny and get the suspension done. I did some searches but I could not find what I'm looking for, there was a post on here a while back where the guy listed all the parts he was getting for a NA engine build, does anyone have the link to that? or do you know where I can look?
my goal for this build is somewhere between 200-230hp. any suggestions on how to get there? I'm thinking of fully-balanced bottom end with aftermarket pistons, rods, etc., ported head with new valves, springs and cams. Should I go with adjustable cam gears as well or what?
basically, what are the things I will need to reach my power goals? I want this to be a daily driver that I may be able too autocross one day.
Don't bump your thread. I would recommend finding posts by dr1665. He is the man when it come's to N/T building. I believe he is running like 11.5:1 compression and fully built motor. And to get to 200-230whp you are going to need a lot of parts. Not sure if you can do it N/A without spray. More compression. Porting and some mild cam's should get you close though.
if I can get around 200 that would be great. and I don't want nitrous, thanks though, I'll search for him.
