Resolved BSEK rear bearing doesn't fit!
jen_cairo
193
Jan 6, 2009
belvidere, Illinois
So I went to install me new STM BSEK and come to find out the rear bearing does not fit I tried all 3 that came with the kit and there all way to small. I bought the block from a good friend and he said he took it to a machine shop it appears the balance shaft area has been machined for some reason.
I was wondering if i can plug this hole with something or what to do.
Thanks
I bought the block from a close friend out of state. there are no bearings currently in the block. just the lower middle hole is bigger than the other one.
does anyone know where to get oversized bearings or if i can fill the 2 holes with metal filler? or something safe that will hold? thanks
For all you that have this same problem I ended up taking it to the machine shop and they put a plug in the hole and put the plug back in the block. If anyone is interested in pics just pm me and i will send you some of how they fixed this issue. thank you!:D
