BS bearing installation problem
herms99gst
515
Sep 5, 2009
stanley, Virginia
I was trying to install my bearings to according the the vfaq on the site. I used the paper towels inbetween the bs bearing and the socket. I went to knock them in and i split two bearings. Do they make i tool a can just buy to do this? The front bearing isnt a problem...which i installed first like an idiot and than had to pull it back out...its the two in the block that are giving me problems. Any sugestions?
For the rear bearings i just use the balance shaft thats on the side where there is no oil hole and knock the rears out (one side is bigger than the other side). Are you replacing them or just installing them for the bs delete?
