BS bearing
dadadadadada
Feb 5, 2006
morrisville, Vermont
I am having some trouble getting my balance shaft bearing out so i can replace it. I am removing the balance shafts and need to block the oil hole. This bearing is the one in the middle of the block and cannot be accessed easily. I have tried to hit it out with a small tipped screw driver and a hammer but it won't come off. The bearing is stuck and I can't seem to get it out. I need some help on what I should do to get this thing out, it's the only thing holding me up on my engine build. I'm sorry if my description is bad but here is a pick of the block and the arrow is the location of the bearing:
(I'm sorry if it is small but i had to meet the requirements for the attachment) not a 2g, a 1g, hit the wrong button
I use a cam bearing remover/installer. If you have a machine shop local, they might let you borrow one. If not, use a brass punch to tap it out.
