Broke a fuel rail bolt
your pretty much gonna have to pull the head so you can get a good angle on it to ez out or use a bolt extractor. you MAY be able to get away with just pulling the intake manifold and fuel rail and do it with the head still in the car
I would first try a punch and see if you can try to turn the bolt. If not than a reverse drill bit or drill and easy out. You should have plenty of room with the fuel rail removed.
