Brakes suck
norco kid
Sep 29, 2007
Montreal,
My brakes have gotten really shitty. They won't lock up the wheels anymore, I can push the pedal all the way to the floor and they just slow the car down. I've changed the master and bled the system 3 times. This is on a 93 FWD with single piston oem calipers and EBC green stuff pads up front/cheap pads in rear. What should I do?
-Adam
Sounds to me like you still have air in the system. Have you checked all the brake lines for cracks/ holes? Are you sure you are bleeding them correctly?
id say just check your lines, because if you blead he brakes right there shouldnt be any reason y it still feels slugish, make sure your rotors arent burnt or worped, just because you dont peel the worpness doesnt mean there not still worped, if they are they wouldnt grip the pad right if your pads were still good, check your pads, if there even the slightest bit close to the metal say like and 1/8 of an inch away that is still bad, also be that your master cylender isnt sealed were the lines go in, might have to replace the whole master cylender if everything is fine.:dsm:
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
