brake light's not working
copper90
82
Apr 4, 2010
EL Paso, Texas
Hey guy's i have a 91 awd talon auto and my rear brake light's stop working. i've replace the brake switch and the light bulbs and still nothing. if anybody can help thanks..:)
Ha Ha!
Get a multi-meter. Find a way to keep the brake pedal depressed. Start at the bulb and check for voltage if you get 0 then move to the next harness towards the brake pedal. Keep going until you find where voltage and then replace the wire/component that failed. Check brake lights. If they are still off, redo the test until you find the 2nd/3rd/4th etc. failed wire/component.
**edit**
This should NOT be in the Handling Tech section.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
