trapspeed
- 1,187
- 3
- Jun 16, 2004
Sacramento,
California
Where do you recommend going for a brake job? I just need the fronts. Not overpriced, either. Thanks.
It doesnt take very long at all, the back ones are harder if you could actually say that it is hard.Not required, never a bad idea to flush out the crap sitting in the calipers. Since most people never bother to change brake fluid, flushing the system when you change pads makes sure it gets done. You can push the pistons back in without ever touching the bleeders, so air never enters the system.2GeNTSi said:Is it really necessary to bleed after you replaced you brake pads?
slugsgomoo said:well, yes, changing your pads is quite quick. However, if you don't turn your rotors at the same time (or replace if they are too worn- though you need to get new ones turned as well, because they are *NEVER* true)-- you will be replacing the pads again, way, way before their time. Plus, depending on how bad the rotors are you may also get weird pedal feel and inconsistent braking.
Don't mess around when you do brakes. Do them right the first time and you'll be much better off. Shops that turn rotors = good. Shops like firestone that "resurface" with a die-grinder = satan.
Take that for what it's worth. I've done a *lot* of brake jobs professionally.
