BLACKCARBON
- 95
- 4
- May 13, 2009
NY,
New York
sorry i could only post here
this is the valve from u.s. plastics corp
does the pic show the right way the valve should be facing
car has 272 cams,ported race build,75mm magnus manifold,apracing 4piston brakes
i currently have a vacuum canister hooked up to the brake booster to help at low rpms.
i just got the valve to see if i can eliminate the vac. can
but unsure which way the valve should be facing.
i tried both ways and it wasnt any better than having the can hooked up.
the brakes are rock hard reguardless of rpms but the car stops.
hooked the can back up and the brakes work fine(not as good as stock though)
would rebleeding help?
anything else i should do to help eliminate the can
thanks for any help
thanks for any help
