Braided SS fuel Lines SAFE?
4g63telantra
454
Dec 10, 2004
Toronto,
Just wanted to know if there is anyone here running SS lines from the gas tank all the way to the fuel filter.
Is it really safe to run SSlines under the car close to exhaust system?
The answer is yes it's safe,the lines are actually run of the subframe,meaning you're supposed to secure the SS fuel line to the sub frame where you jack the car up by using a j shaped hanger which is then bolted.
Just search SS fuel line installand I'm sure you'll run into some picks to make what I said much more feasible to understand.
